79 C10 5.3l swap setting up for auto x
#71
good idea on the sterring box reinforcement. had a 86 where it cracked real bad. drove to mufflershop an had them weld some diamond plate an was good to go. i plan on buying the kit from offroaddesign for my 84. nice burnout
#72
Thanks. I can't go all the way in the throttle becuase it just spins like that. Even the freeway in passing gear it will kick the rear end a little when it down shifts. Its scary. I need larger rear tires and some sort of two link or track bars from the axle to the frame by the reat cab mounts.
#76
#80
VERY VERY rough but an idea I can't stop thinking about. I want my 295s back in the front but If I can fit larger then hell ya! Haven't figure out the rear I was thinking of cutting the fender at the body line and spacing it out 3-4" the frint would be a little less dramatic. I just want larger tires and to look sporty. Anyways what do you guys think?
