79 C10 5.3l swap setting up for auto x
Nice build man. Sorry if I have more questions than answers. What mounts did you use for the engine swap, trans if any? Why the 8 lug conversion and where did you get the bucket seats?
I used transdapt plates from ebay. Trans mount was stock just lid back. I am switching to 8 lug to match my 14 bolt rear end. The buckets were from the junkyard out of a mercury tracer.
I swapped to a 14bolt because I destroyed the 10 bolt. I somehow sent the pinion back into the carrier and it locked up destroying it. Searched for a 12 bolt locally but a guy was getting rid of a 3b4 ton suspension so I grabbed the spindles and lower control arms and axle. Th axle is larger but should be stronger and I will be swapping over the front to match the 8 lugs. The lower control arms and spindles are the same size roughly and have bigger brakes. Not much more wieght, but with the 5.3l it should even out.
In regards to the weight I was only referring to the ront end. I was hoping for a little more weight in the rear anyways because there is nothing back there. Not that much lol. I am planning to convert to disc in the future so that should shave some weight. I just didn't want to mess with another busted rear end.
So i test fit the new rims i got on the 3/4 spindle and rotor and the rim hit on the spindle. i bought these 8 lug 15x10 rims for this build and was planning on running them all around but it appears that i will be finding some 5 lugs to match the rear and just continue on with the suspension. i want to flip the rear and drop the front with maybe drop spindles and a coil. not sure how low i can go. i am running 15x10 in the rear with a 295 series tire currently with plans to go 315 or larger if i can fit it. In the front i am going with a 15x8 and a 295 series tire. I have run this setup on the front for years and havent seen rubbing yet. i am hoping that with the 4" of backspace on the front rims i will be able to get the nose down 4-6". The rear i plan to c-notch and flip which should get me down 6" or more. maybe shackles if its not low enough.
Hi,
I have a 1979 c10 with a 5.3l swap and a 14 bolt rear end. i am going to start setting this up for autocross next spring. I have the front suspension parts to convert my front end over to the 8 lug stuff to match the rear and i am using this to tear into the front and replace bushings and what not. I already have a blazer tank and my battery where my tank used to be. bucket seats installed to make the roll cage a little easier. Just looking for any tips or hints anyone may have in the suspension area. i am looking to run some 18 x 8 or 18 x 9 8 lug rims and 295 or larger series tire. maybe a 4 link if i can find a setup i like.
i talked with the guys at the hotchkis truck yesterday at the del mar show and they said the 73-87 series suspension is on the list of trucks they will be looking to build in the next year or more. he said a leaf spring setup would respond well with properly tuned leafs and a panhard. not sure if i agree with that but we will see.
any one have any help?
Same setup that Nascar uses, for my old 70 it seemed to work really well with a 5/7" drop. Search for "Spoolin" and you can see a more modern variation. Something that will allow articulation and keep the axle centered for the weight being pushed. Whats the budget allow for?
