Two-piece to Single Piece Driveshaft
Old 09-27-2014, 12:26 PM
LQ4 Tank's Avatar
Default Two-piece to Single Piece Driveshaft
Any one here do the two piece to single piece driveshaft conversion? I've searched all over and nothing really gives me a good answer. I have 2001 GMC 2500 HD CCSB, afetr my lift I get that same old shudder in the driveshaft and all the stop-and-go traffic in College Station is making it worse, wanting to swap to the single piece. Can I just go to a junkyard and pull a driveshaft out of a new rig or is it not that easy?
Old 09-27-2014, 03:44 PM
Jason Z69's Avatar
Im not sure if u can do the junkyard thing. I think u may screw up ny goin 1pc tho. U may need to replace the ujoints or even the carrier bearing/center support. I have a 1pc aluminum drive shaft and it vibrates at 85mph. Im goin 2pc next week. I just ordered it yesterday. The newer drive shafts are only rated for 100mph. After I changed my 3.08 gears to 4.11s i had the vibration. I really think its probably the carrier bearing or the u joints in your case. U may need to get ur d/s balance. I had a 03 ccsb 4x4 with a 4l80. I had the same problem. I changed all ujoints and carrier. Good to go.
Old 09-28-2014, 02:02 AM
LQ4 Tank's Avatar
I just swapped carrier bearing out about 1,000 miles ago. Had the professionamals do it too 'cause I didn't feel like building a puller to use on the press. It only shudders when I'm at a stop. From 5-125 it's as smooth as can be. I've seen kits to drop that center support down for lifted trucks so I'm wondering if my lift causes it? I never noticed it before. Needed traction bars bad though, it was crazy how much wrap I had after the lift. So I may look into that little drop kit and see how to fabricate my own. I figured a single piece was more efficient than a two piece but I guess not.
Old 09-28-2014, 02:21 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
You may need to install a spacer for the support bearing. I'd recommend measuring the operating angles of all the u-joints, and go from there. May also need to use shims to change your pinion angle. And of course you need to make sure all of your u-joints are okay.
How big is the lift kit?
Old 09-28-2014, 02:26 AM
LQ4 Tank's Avatar
Just a 6" Pro Comp lift, but it's only 4" blocks in the back so I'm not quite sure how it's 6" of lift in the back. I guess if it's just to steep of an angle it's gonna shutter right there until it's smoothed out and into a constant movement. It's not too bad with the trac. bars on but still shutters a bit, and it's about to get quite a bit more power thrown at it so if the two piece was a weak link I wanted to get it out of the way and throw a single piece on.
Old 09-28-2014, 03:27 AM
If your angles are set up properly, the 2 piece shaft is stronger than a 1 piece shaft.
Old 09-30-2014, 10:30 PM
LQ4 Tank's Avatar
How is the two-piece stronger? Not doubting you by any means, just figured that center support is a weak link.
Old 10-16-2014, 04:24 PM
cjcullom's Avatar
Just because its new doesnt mean its any good. Just replaced a "new" carrier bearing in less than 400 miles.....cured the problem though.
Old 10-16-2014, 07:03 PM
LQ4 Tank's Avatar
It was shuttering way before my "new" carrier bearing. That's not the problem. I've had the problem ever since the lift. I only replaced the carrier bearing because the rubber that surrounds it and holds it in place has been longgggg gone.
Old 10-17-2014, 06:27 AM
dirt track racer 81's Avatar
Two piece is a lot stronger than a one piece. Long one pice shafts are known to breaking and having bad vibration issues
Quick Reply: Two-piece to Single Piece Driveshaft
