Thoughts on 4" exhaust on 6.0 2500?
#23
My 2001 1500HD has 2.9" pipe to the cats then necks down to 2.75" to the muffler. After the muffler it's a single 2.75". I also believe it is the same exhaust the 8.1 uses. As in my opinion it is way too big for the 6.0.
#24
#25
#26
#27
Whats the part number on that magnaflow 4 inch catback?
#28
The "lost bottom end" is usually one of two things, or both: you can feel the increase at the top end and mistake the stock low end where it doesn't yet need the flow, of being less (most likely,) or a tuning issue. Backpressure is bad! If, as the old wives tail was actually correct, and its not, then racers would all have an RPM adjustable "backpressure device" to enhance performance all across the range. No one does. It's been tried. Many times. As long as you have at least about a foot of pipe after the header or manifold, you are fine. The pipe the diameter of the manifold helps keep the velocity up, after that a bigger pipe helps the flow. GM got that right! They would have seen gains with a 3" manifold outlet, but the 8" or so 2 1/2" extension is good. Many dirt track stock class racers have removed everything after the manifold and found losses there. Also, having no pipe on the end of a muffler is bad too. About 10"+ of pipe after the muffler helps the scavenging and HP. Even a turndown helps. TIMINATOR
Suburban2500
07-19-2015 04:50 PM
