Low fuel pressure at the rail.
Old 10-05-2016, 10:44 AM
mhotrodscooter's Avatar
Default Low fuel pressure at the rail.
What are some of the causes for low fuel pressure at the rail? This started to happen after my trans had failed and went into limp mode. Not knowing what had happen at the time I stayed in it, and made it hit the blow off a couple of times. Changed the fuel filter and took it for a hit. It done fine. Couple days later I make another hit and it acts up. Really only does it in 3rd and got to let off the pedal for it to shift and then it seems to do fine. Put a gauge on it a vacuum at the rail is around 12-15. So it's restricted somewhere. Any help would be appreciated. 06 Lbz
Old 11-14-2016, 08:55 PM
13 Second Truck Club
grey matter 04's Avatar
How big of a tune ? Fuel filter good ?
Seems like the cp3 pump is weak. A fuel rail plug will band aid issue .
Old 11-27-2016, 07:58 PM
it either has restriction between the tank and pump or the injection pump has failed. If in doubt put a 5 gal bucket of diesel on the pump suction side and see if your rail pressure is normal.
13chevy
10-15-2016 03:52 PM
trxmxzx
09-21-2016 11:14 AM
maxspeed05V
09-08-2016 06:53 PM
Silverado256
09-08-2016 06:17 PM
06 4.8
09-07-2016 07:02 PM
Quick Reply: Low fuel pressure at the rail.
