Finally! Modified Stock 8.1L Intake Manifiold Numbers!
Old 07-15-2014, 04:48 PM
Raylar Engineering's Avatar
Originally Posted by RezinTexas
got any pictures of the "burban" ?
I'll do one better: here's a video of the truck as it sits today.
Raylar 540 Stroker with Modified Intake Manifold - YouTube
The modified stock manifold makes 25 more peak horsepower on stock heads and the same peak torque - but with great improvements over the stock powerband.
At this point, we're completely convinced that this is the upper limit of the stock cylinder heads (even with porting) without switching seats and putting larger valves in. The stock iron heads are coming off and a set of Raylar aluminum cylinder heads will be going on the Suburban.
**On a side note, there has been some talk with Whipple Superchargers about creating a completely new 2.9L blower package for 8.1Ls on the street.. Keep your fingers crossed on this one!!
Old 07-17-2014, 02:35 PM
Kerr's Avatar
sound good! is 2.9L enough? the old 1.9L was a joke waste of time and money on a 8.1L ad in your CI and im not sure you will be happy with a 2.9L
Old 07-17-2014, 06:27 PM
Praise The Lowered
RibeiroBJJ's Avatar
Very cool! What part of San Diego are you guys in??
Old 07-18-2014, 11:41 AM
We initially asked for a 4L but the team at Whipple said there was no way it would fit under a stock hood / firewall / cowl. We'll see what ends up fitting/working in the coming months.
Kearny Mesa.
Old 07-21-2014, 11:20 AM
02_2500avalanche's Avatar
So exciting to hear whipple has something in the works for us....I have been meaning to call them forever. I want the 4l jack shaft set up they make for the 5th gen camaros....I think there is room
Old 08-23-2014, 10:39 AM
xx_ED_xx's Avatar
I vote twin turbos and the new intake.
Once i get my ls1 s10 running, back to work on the silver truck. I plan on mild port job stainless valves and bigger exhaust valves on a stock set of heads til i can buy the aluminum extreme heads from you guys. oh and 30 pounds of boost from an 85 mm turbo
Old 08-27-2014, 10:23 PM
I thought the silver truck was running our heads / cam etc??
30lbs of boost! Do you have the forged rotating assembly (pistons / rods / crank)? I know you already know this, but boost + cast pistons can create more problems than its worth!
Let me talk to Larry, but I'd bet if you wanted to pay the shipping, the ported stock heads off the shop Suburban could probably be yours when we put the aluminum heads on the 540. You're probably only going to get another 20-30CFM out of them, and you'll still have to have new seats / valves put into them, but at least it saves you the 10 hours of rust and misery that is grinding down stock iron heads.
You'll still need springs, roller rockers and a boost friendly cam - but you already know who has all that.
Old 08-28-2014, 05:15 AM
xx_ED_xx's Avatar
i had a set of your heads but the previous owner damaged them and i didnt trust them. I'll do one better I will come to your shop and pick them up. And yeah i need to buy rockers
I will be in LA to pick up a car for a friend and i was debating swinging by your shop since it is only a few hours south.
Old 12-23-2014, 03:34 PM
Kerr's Avatar
a 4.0L would be SICK!!! just have to cut the hood, be like the ZR-1 corvettes lol.
man your dyno pull goes for ever! how was fast was that... this is mine but i have 4:88 gears to turn the tires...
Old 12-23-2014, 08:25 PM
xx_ED_xx's Avatar
Whose dyno pulls?
ARC
57
02-21-2022 10:54 AM
GrooveCityZ71
08-31-2015 12:05 PM
Raylar Engineering
08-26-2015 10:36 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
Quick Reply: Finally! Modified Stock 8.1L Intake Manifiold Numbers!
