DMax gas mileage?
Old 09-22-2016, 12:09 AM
graysilverado5.3's Avatar
Originally Posted by ltr450ryder
I've nvr seen A duramax get better then 22-23 and those are all
Lb7's which get the best Mpgs out of the dmax not lml's. Lol
Forgot to mention I was deleted, but even at that, a buddy of mine would see 19-20mpgs on his stock 12' dmax.
Old 09-22-2016, 10:24 PM
Formerly PurplePearl (2014-04-06)
Mortiz's Avatar
My lml gets 12 no matter what I am doing. If you want fuel economy you need to delete and tune the new stuff.
Old 09-23-2016, 09:29 AM
ltr450ryder's Avatar
Good luck you might wanna hand calculate it then istead of using the dash lol. My buddy has a 13 deleted and his best is only 19.5 so good luck to you and your buddy.
Old 09-23-2016, 10:14 AM
I edited my post, it was not 28mpgs, it was 25. Actually 25.4 going off the dash. How far is the dash off since you know my vehicle and how much difference there is using the dash calculations and hand calculations. FYI, my hand calculations and the dash on my vehicle were spot on.
Old 09-24-2016, 09:38 PM
Whitecrewcab's Avatar
My stock 11 LML would get between 17.7 and 18.3 unloaded, all stock if I kept the speed down. Deleted and tuned, I saw 21.3 running between Delta Junction and Fairbanks, but the speed limit is only 65 and lots of coasting down the back sides of hills. Summer months it averages between 19 and 19.3 with my commute to work and back, but don't even ask about winter mileage since you have lots of warmup idling.
Old 12-01-2016, 04:14 PM
Registered User
CDUBCustomz's Avatar
When I first bought my 2007 LBZ I hand calcd 23.5 MPG on the 13 hr trip home.
That was bone stock everything, 90% highway, but had some decent hills in there too.
Old 12-06-2016, 06:46 AM
Registered User
Nick Beasy's Avatar
I have a 2000 Silverado 2wd reg cab fleet side that came factory with a 5.3 LM7 and 4L60E......Yes 5.3 factory on a 3/4 ton......Am i stupid, or what? Any advantages i may have? Seems like a strange marriage to me......Thoughts?
Old 12-06-2016, 07:03 AM
9 Second Truck Club
stock48's Avatar
I've seen 20~22 at absolute best on highway unloaded out of my 07 lbz with ppe 90HP tune. 65 mph flat highway. At 75~80 mph I normally see 17.5~18 range on flat and 16~17 with mountains and wind. Truck is a ex cab 4x4 with 285 tires.
Old 12-06-2016, 11:14 PM
Wolftrk99's Avatar
Are you sure its a 3/4 ton, somone didnt just throw badges on it? Is it 6 or 8 lug??
Old 12-06-2016, 11:36 PM
Registered User
Nick Beasy's Avatar
Yessir....8 lug and 3/4 ton leaf springs.,.. I even went to dealership and had them print me out a build-sheet by entering my vin number into their database.....The badges say 2500 as well but no HD......Seems weird to put 3/4 ton heavy duty suspension and axle under it and then go and put the 5.3L w/ 4L60E powerplant in it......Pointless? I have a fuel efficient 2500 that overheats the trans if i use the HD suspension as it was intended...
Quick Reply: DMax gas mileage?
