DMax gas mileage?
I edited my post, it was not 28mpgs, it was 25. Actually 25.4 going off the dash. How far is the dash off since you know my vehicle and how much difference there is using the dash calculations and hand calculations. FYI, my hand calculations and the dash on my vehicle were spot on.
My stock 11 LML would get between 17.7 and 18.3 unloaded, all stock if I kept the speed down. Deleted and tuned, I saw 21.3 running between Delta Junction and Fairbanks, but the speed limit is only 65 and lots of coasting down the back sides of hills. Summer months it averages between 19 and 19.3 with my commute to work and back, but don't even ask about winter mileage since you have lots of warmup idling.
I have a 2000 Silverado 2wd reg cab fleet side that came factory with a 5.3 LM7 and 4L60E......Yes 5.3 factory on a 3/4 ton......Am i stupid, or what? Any advantages i may have? Seems like a strange marriage to me......Thoughts?
Yessir....8 lug and 3/4 ton leaf springs.,.. I even went to dealership and had them print me out a build-sheet by entering my vin number into their database.....The badges say 2500 as well but no HD......Seems weird to put 3/4 ton heavy duty suspension and axle under it and then go and put the 5.3L w/ 4L60E powerplant in it......Pointless? I have a fuel efficient 2500 that overheats the trans if i use the HD suspension as it was intended...
