center force vs spec clutch for NV4500
Im in btween center force and spec clutch
I also need a flywheel , the first one damaged
centerforce DF997997 with flywheel 725$ vs spec stage 3+ SC563F 570$ without flywheel
any other brands that ar proven ?
how long have you been running it ?
if you guys wonder what is it going into , its for a 2006 GMC 2500HD nv4500 4x4
with a 408 droped in it as a daily/offroad truck
I guess i'm a little late but i'll chime in none the less...
I ran a centerforce(same part number as you) for a little over a year, it snapped the master cylinder out of the pedal assembly 3 times, always breaking the pedal assembly. It was also very difficult to shift at high rpms as the spring was so heavy=much slower shifts.
I purchased the centerforce after I installed the blower at 50k miles and the stock clutch wouldn't hold. Well I had abused the stock clutch initially quite a bit, stuck in sand, stuck in snow etc.
I put a stock replacement clutch in at 80k and it is still holding now at 156k
just my experiences, other people have different ones.
In between I ran a mcleod rst rwin disk for about 7k. It got hot and wouldn't fully disengage...problem was I use the truck for work, lots of weight in truck and heavy trailers, maneuvering around a construction site you need to work the clutch and slip a lil to back up trailers etc. The twin disk doesn't really like that...
I know I am due sooner than later for another clutch leaning towards another stock one right now.
Good luck
Good luck
dang , I already bought one , the truck in question is a cambping/dd truck
it has almost 2500-3500 LBS load
60 galons of water and $hit load of tents and wood among other stuff,
well , we are just gonna have to try this out
because the spec didnt work , and it damaged the fly wheel , so the only one reasonably priced with a flywheel is the center force
the OEM flywheel alone will cost 250-275$ not to mention the clutch
and th mcleod is way too pricey for my customer .
FlowmasterMufflers
11-24-2015 01:00 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
