Building '00 2500 4x4
So pretty much ANY aluminum head from '01 and up should do? Stupid GM changed stuff around so much it's hard to keep up with what is what. I need a shopping list of what head is on what and what years....😡
Ok, so I think I'm understanding more about GM and their craziness. I'm actually looking now at a '02 LQ4 that has the 317 heads. Its in pieces right now. Machine work done on block, everything cleaned and ready for assembly. I think I might just buy that, assemble it with new TSP cam, springs, pushrods etc, that way when I pull the old engine I can just drop the rebuilt one in and have minimal downtime.
Both motors are in front of 4L80e trannys. I thought my motor in the '00 was the only one that had a flex plate with an adapter? I thought the newer ones mated up directly?
Well that sux. They actually changed the crank so I can't even swap MY flex plate onto the other motor and stab it back in.....I better make sure this other one has the flex plate and adapter then. Thanks for the info once again.....
https://www.performancetrucks.net/fo...-parts-544461/
If youre still looking and hadnt seen this yet....
About20ninj45
20
03-01-2016 08:58 PM
Garrett12895
02-22-2016 10:42 AM
