Building '00 2500 4x4
I'm buying my nephew's 2000 nbs Silverado 2500 4x4. It has the 6.0 and 4L80e. Not for sure how many miles are REALLY on it but at this point it's kinda moot.
My plans for it include rebuilding the engine with a nice cam to pick up some low and mid range power, freshening up the trans with a shift kit and new TC, putting some long tubes on it and a full dual exhaust, lift kit with 35s and regearing to 4.88 with a Tru Trac in the rear.
Body work and some interior work needs to be done but mechanically is what I'm concerned with right now.
When I go into the engine, I'm sure that I'll need to replace the injectors and probably deck the heads and bore it out. I'm not looking for a race truck but one that will put out good reliable power. Is there an upgrade on the heads I can do? Maybe some newer model heads? Are 8.1L injectors worth putting on with a mild engine build? What about upgrades on intake?
If the bottom end is still solid and no oil pressure problems or crazy sounds, it should be just fine as it is. I don't see a need to rebuild it but I guess that your money and your choice.
If they have iron heads, get rid of them. Though I think most all 2000's have the Aluminum 317's, they already flow great and don't really need any work. Depending on cam choice and power you want to make, you may as well just toss some 8.1 injectors in there. Stock truck intake is great, they will make great power as is. I would get a intake tube if they make them though, they flow so much better than the stock intake tub with baffles.
Honestly this thing was beat by my wife's uncle out in deep west Texas since the day he bought it. My nephew bought it cheap but didn't want to put the money into it to get it right and I love these older trucks like this so I'm going to make it a beast.
A CAI is definitely on the parts list. If for some reason it has iron heads on it what year heads should I be looking for? If they are aluminum are they going to be the cathedral heads I am reading about?
Won't the higher compression heads require premium fuel? I'm trying to stay with 87 octane if I can, not really wanting to pay for premium unless there is no choice to get what I'm looking for.
Ok sorry I misread your earlier post. I'm pretty certain it's going to be iron heads on that year LQ4. What specific engines and years should I be looking for to find 317s or any of the other heads? I need to be looking because I will be tearing the top end apart in the next couple of months and I'm starting to line up parts.
Aside from cooling issues, what is so bad about the cast iron heads?
They flow like and they are heavy as hell.... 317s were used starting i think it was in 02 On the 6.0, .....if you decide to run the 799s they are on all the 4.8/5.3 from 07 up so they are becoming rather plentiful... Sad prt is i gave away a perfectly good set of 317s when i cleaned out my buddies garage after i was done with my engine....
