8.1L K20 Build
#21
At this point I know one thing is for SURE. I will be using your pistons for sure. As far as cam goes Im still up in the air. I know its from you just not sure which one as I will be running stock heads. What Im worried about with the 205 cam (which is want I was wanting) is the valvetrain not holding up. Not wanting to buy longer valves, super stiff springs, cut pockets, and all that jazz if thats what a 205 requires.
If it does require that then a 203 is what Im after.
Larry, have you guys increased compression say 1 point on stock heads and seen any gains? OR ill effects? Not by shaving heads but say by decking block. Not even sure if that can be done cause I never measured piston in the hole beforehand.
#22
Do not mill the heads or block for a bump in compression. If there is damage you can cut them down minimally, but I would suggest a thicker head gasket to make up the difference or you'll be venturing into detonation land. Frankly, the stock cylinder heads are throw away items. Extensive porting (roughly 12-14 hours of work) will get you 10-15hp - provided you don't go through the exceptionally thin wall castings. If you want 10 to 1 compression, buy aluminum heads.
thehatchninja
03-17-2016 08:33 AM
