2 Power steering pumps bad?
Old 12-23-2015, 09:22 AM
d-bo71's Avatar
Default 2 Power steering pumps bad?
I have put in 2 PS pumps with the same results. Upon installation I put fluid in moved steering to lock to lock several times. I start vehicle and everything is fine, a few minutes later I have no Power steering but if i rev power steering comes back. This is the 2nd pump in 4 days no way both pumps are bad out of the box with the same exact symptoms, ANY HELP?
Old 12-25-2015, 03:59 PM
Registered User
DRX350's Avatar
Okay, not trying to insinuate anything at all, but is the belt slipping? Other than that, how's the r&p?
Old 12-26-2015, 12:50 AM
Wolftrk99's Avatar
Are the pumps new or remans, what year truck, what type steering system(gear box or rack), and what mods are done to truck???
Old 12-26-2015, 11:13 PM
d-bo71's Avatar
I thought i was in the 8.1 section? Minor mods headers, intake, tune, exhaust. Reman pumps 3rd times a charm replaced hi-pressure lines and did the correct hydroboost bleed sequence and everything is cherry. Thanks for the responses
Old 12-26-2015, 11:42 PM
Wolftrk99's Avatar
Haha yeah the first two more than likely had the wrong valve in them... Ive had times where after the third pump i finally just had to get the writer or manager to order the valve from a dealer and swapped it out.... And all was good, happens a lot with hydroboost 8.1 or not!!!
Old 01-01-2016, 01:37 PM
Camaraderie's Avatar
I've heard oem is best . I was told vato zone and hoe reillys parts aren't the best whenever it comes to these types of parts .
Old 01-01-2016, 02:11 PM
Wolftrk99's Avatar
Most aftermarket remans are junk. Had best luck with napa and oem....
GM1697
03-13-2016 01:52 PM
madmann26
02-10-2016 12:34 PM
MWRitter
12-28-2015 06:07 PM
DopdBrd
12-17-2015 07:21 PM
Quick Reply: 2 Power steering pumps bad?
