1998 7.4 vortec performance upgrades
Old 12-19-2012, 09:37 AM
Registered User
MaineK2500454's Avatar
Default 1998 7.4 vortec performance upgrades
I am saving my money to overhaul my truck I would like to make it the ultimate tow/work truck. Right now it is under powered and slow I would like to put
-heads no bore or stroke needed
-cam whats a good one to run for torque
-square port intake system
-30 lb/hr red top injectors
-four barrel throttle body
-volant intake
-eaton posi
-hooker headers ceramic coated, 3inch to the cats, 3 1/2 cat back true dual dynomax round ultraflo welded and high flow cats
and maybe a supercharger later on down the road
I will also put a leveling kit add a leafs 285/70r17 Bfgoodrich mts and Mamba rims
My truck is a 1998 K2500 L29 454 factory auto
I will need to do a little bit of rust work and some other odds and ends.
This is a work truck and will be used for work just needs more power.
Old 12-19-2012, 09:53 AM
fastnnuffrt's Avatar
Mayb check on how much all that's gonna run you. Might be easier and cheaper with better mpg and reliability to find low mile 6.0 and swap
Old 12-19-2012, 11:24 PM
xx_ED_xx's Avatar
trust me a 6.o cant touch that at same compression because of the displacement
those things always need injectors and fpr
get away from bosch injectors , I ran the edelbrock slash gm perf heads on mine
1.8 rockers on a stock cam is a decent upgrade and the proo flo intake will help a bunch the stock intake sucks for performance
headers and true duals
used to have that engine in my 04 silverado before i went to the 496/8.1
Old 01-08-2013, 07:40 PM
Registered User
I do not want to even mess with a ls based engine when it comes to codes. I do most of the work myself with hel from my brother and friends and we do not have the equipment for them. But I have changed my mind again. I would like to twin turbo it now from seeing what other people are getting for hp and torque.
From what I have found it will cost around 7 grand for heads, fuel system cams, crankshaft, pistons, rods, tranny and turbos with piping. With everything else I would like to do to the truck it would be a total investment of around 12-15k and not having a payment on top of that.
It would be epic to pull up next to a pos ricer or some pile like that and tow them at a red light. Also kick my bosses challengers ***.
Old 01-09-2013, 03:32 PM
Registered User
Ok so here is my updated thought
-turbonectics ball bearing twins with intercooler and water meth twin gt-k 650 or a single gt-k 1000 oil and water cooled
-3" down pipe to 3.5" down pipe back true duals
-80 lb/hr trick flow injectors
-502 ported ram jet intake
-brodix heads race rite ovals 119cc combustion chamber and 270 intake runner ported polished machined
-ported and polished intake manifold
-arp head studs
comp cams 226in/218ex duration 525 intake and 514 exhaust
-411 pcm with efi live
-still not sure on pistons most likely will convert the tranny mounts to a 4l85e for better build options to handle the power most likely wiseco or manely
-manely rods and a upgraded crank
-It will be bored .010 over and be able to run on 89 and have propane injection.
the goal is 600-700 horse and 900-1100 torque
Old 01-10-2013, 10:52 AM
buick_93's Avatar
What kind of gains did you see with the Pro Flo Intake over the stocker? I've had my eye on that intake.
Old 01-10-2013, 12:44 PM
Registered User
But how many people say they have a truck with a 454 stock. Also everyone that is selling a 6.0 up here is either blown or over 150k+ and most likely rebuilt and abused. I am going to buy a second engine to put all the mods on so I can still use the truck. Then build the stock engine the same way and put it in a 70s c10
Oobray
06-13-2022 03:38 AM
cbhedrick
07-20-2015 10:12 PM
ROB 1 TON
07-13-2015 04:43 PM
4B11T
07-13-2015 03:48 PM
GRRR65GTO
07-10-2015 08:27 PM
Quick Reply: 1998 7.4 vortec performance upgrades
