06 LBZ Duramax will not start - video
Old 02-17-2016, 03:07 PM
Tootall's Avatar
Default 06 LBZ Duramax will not start - video
260k miles
It's been sitting for about a year
no check engine lights
It was religiously maintained at one time, but not for the last 60k miles or so.
Spent most of it's life as a yard truck pulling a hydro test trailer around the yard and a few repetitive road trips.
The engine will crank, but not start.
I've replaced the entire fuel filter head assembly along with a new filter.
Purged with the vent screw open, and it gets solid fuel coming out
A few more pumps until it starts to get a little firm
I can crank the engine over, but it has erratic cranking. It will pulse crank, slow crank, skips crank
All while holding the key forward, it will stop cranking on it's own.
After 12-15 attempts of priming the pump, it will fire for a few short seconds and then die.
Any suggestions?
If I put the trans in neutral, it will not roll. It acts as if it's stuck in gear. Could this also be an issue?
Old 02-17-2016, 03:41 PM
FFDP's Avatar
I bet it won't move because the brakes have rust build up on all 4 corners and it needs to break that free first to move.
Have you tried cleaning the battery terminals yet? Possible electrical issue??
And starting and dying right away could also be a security problem.
Old 02-17-2016, 03:45 PM
treylittlefield's Avatar
Maybe the starter? My dad's lb7 would crank but not start. Replaced starter and both batteries and it fires right up. Doubt it's that on yours, bit worth a look
Old 02-17-2016, 04:11 PM
Tootall's Avatar
the fronts roll just fine.
I was going to disconnect the drive shaft to make it roll. It rocks back and forth as if it's stuck in gear, but the dash lights up in neutral.
Batteries are clean and fully charged. Both are 1000cca.
I'll hook up my HPT tuners and try relinking the VATs
It's been abused the last 60K miles, so there's no telling on the electrical issues part.
Starter is a fresh rebuild. Tested it on another truck
batteries seem to be good.
I'm open to any suggestions. I'm just trying to get it running. I want the engine and trans, the rest will be parted out.
Old 02-17-2016, 11:23 PM
Custm2500's Rude Friend
1FastBrick's Avatar
I would look into a Bad ignition switch or a loose ground.
Old 02-18-2016, 07:57 AM
TXsilverado's Avatar
Possible bad fuel?
Old 02-18-2016, 08:20 AM
Tootall's Avatar
it's possible, the whole underside is packed full of mud from being a yard truck
Possible bad fuel?
could be
Another guy on a board suggested that it might be an injector that's stuck open. That would explain the funky cranking that it does. I'll pull the glow plugs and see if I have a sprinkler while cranking
Old 02-22-2016, 05:27 PM
11 Second Club
MrHorsepowerLSx's Avatar
Did you crack the hard lines at the injectors and crank it in 10-20 sec intervals then close them and see if it will fire. I usually have to do that after a fresh rebuild or injection pump swap on the machines at work
Old 02-25-2016, 10:26 AM
Tootall's Avatar
no I haven't but I will try that next
I did pull the glow plugs yesterday and they were all dry and they are new.
I primed the filter head and cranked the engine over, nothing that would suggest a bad "open" injector. No fuel came out while cranking.
Old 02-25-2016, 11:57 AM
11 Second Club
When they become air bound they are a pain sometimes to get running, you can also crack the injector hard lines and prime away for the rest of the day lol and it should fire. Example: crack the lines pump pump pump, crank, pump pump pump, crank, etc then close the injectors and attempt to start. Then repeat until fuel gets upstairs
Edit: I just watched the video......... Sounds like the ignition circuit has a short somewhere, where at the battery terminal end or the starter wiring. I would remove the solenoid ignition wire and test it to see how long it is actually calling for power, it almost acts like a power to ground short or voltage drop. You never know a critter could have gnawing on the wires
Quick Reply: 06 LBZ Duramax will not start - video
